unz0ne
Установка камеры заднего вида
В теме 461 сообщение
56 минут назад, BSR сказал:
As I see, you have RTi navigation monitor.
Quality of picture from camera (resolution) is less than 2015 SC.
But don't worry, this quality is more than enough for good parking:thumbsup:
I thought that screen is the same for all the cars (facelifted). The control module for the display is different... but i may be wrong.
26 минут назад, kachijs сказал:
No, they are totally different.
RTi monitor has direct camera connection by coaxial.
It's a media center ( half of the source unit) with MOST and other connections.
SC is just lcd panel with high resolution and it has 1 GVIF connector (special video signal) only.
All Source unit function in the dash panel.
Camera not connected to monitor, it connected to source unit.
Signal from camera "goes" to lcd in digital way by GVIF.
10 часов назад, BSR сказал:
Не получится.
Там нет отдельных кнопок и проводов к ним.
Они все смонтированы на общей плате и управляются через мультимедийный can
Жаль.. значит придется что-то колхозить.. так как разбирать парящую и выпаивать кнопку желания нет
2 часа назад, BSR сказал:
First of all - i don't like that the old type camera is screwed from the outside with two screws - someone can easily take the camera out. New style camera is better - it pushes in from the inside of side of the number plate lightning element that is held in with nuts from the inside of the car.
@BSR you are right. Camera for cars without Sensus Connect is connecting to screen directly, but the cars with sensus connect camera is connecting to media box which connect to monitor.
If you want to install new style camera on a car without sensus connect you need:
+ Installation kit, for a car without option code 820 ("Rear parking camera, preparation") 1
and since i dont have any one of the following i also need CEM....... (i think i would be able to get this somewhere used).
+ CEM, for a car without option code 820 ("Rear parking camera, preparation") that does not have one of the following functions: Active Bending Lights - ABL, power folding head restraints or BLIS.⁴
but then under notice they state this:
Note!
Cars without option code 820 ("Rear parking camera, preparation") must be equipped with Sensus Connect.
But the installation manual clearly states steps that you have to take if you have sensus connect and if you don't.
@kachijs,
10 минут назад, kachijs сказал:
In this case best way if you`ll use riveting for camera fixation.
1 час назад, BSR сказал:
Можно вместо шурупов гвоздики вставить и сзади загнуть молоточком :haha2:
45 минут назад, jon сказал:
this would be - what do you call it - kолхоз :D
Изменено пользователем kachijs
I have seen that some of the users makes custom washer for the rear camera. I think most of the users do not have washer on the camera made - how often do you clean camera? When i ride in this weather - snow, rain, dirt.... back of the car gets dirty pretty fast so would the camera....
can you see through the dirt or you have to clean the camera?
@kachijs, Вот сайт для изучения
http://bgtshop.ru/search/?q=омыватель
13 минут назад, BSR сказал:
Офигеть цены.. я вчера все это для своего омывателя за сумму в 15 раз дешевле взял)
Но идея интересная)
i come to my car and clean a camera by my finger/
i haven't a custon washer.
6 минут назад, DaveCage сказал:
And then glass at the camera with scratches
Да и не удобно после длительной поездки выходить и протирать перед парковкой)
Прощу поставить форсунку и помыть камеру
25 минут назад, TABU сказал:
Но идея интересная)
Понятное дело, что по отдельности можно все найти дешевле.
Но для экономии времени такое решение оптимально
17 минут назад, DaveCage сказал:
Фингер хреново очищает камеру если вся ..опа мокрая. На камеру тут же каплями стекает новая грязная жижа и картинка искажается.
Подозреваю что омывайка камеры действует не лучше пальца:xc_thinking:
Рулит только тряпочка:xc_loser:
7 минут назад, BSR сказал:
Заезжаем в магазин автозапчастей АВТОВАЗ.
Покупаем распылитель карбюратора - 31 руб. Трубку 3м с тройником 40 руб. Форсунку от Нивы - 31 руб. (если не распылитель а форсунку ставить планируем) и по желанию клапан - 280 руб.
Все это всегда есть в магазине в наличии.
В итоге имеем комплект за сумму менее 400 руб.
Платить на 5600 за удобство..хмм...это п****дец какой то)
3 минуты назад, gus_dim сказал:
Если правильно поставить форсунку, то камера получается чистая) (желательно чтобы брызгала сверху вниз)
На прошлом авто реализовал, да и отчетов с видео куча.
Изменено пользователем TABU
Только что, TABU сказал:
Я 1000 раз так делал и счас работает
57 минут назад, gus_dim сказал:
Камера установлена так, что на линзу может попасть грязь только аэродинамическим путем.
Естественное стекание грязи не затрагивает камеру.
 а почему вообще камера установлена не по центру? это ж в целом не очень удобно
2 минуты назад, DaveCage сказал:
Зрите в корень, батенька!:thumbsup:
Совсем геометрически по центру не получится, там ручка 5 двери.
Но сделать камеру как у тех же баварцев ничто не мешало((
